February 27, 2023 at 12:58 pm
Borut Omerzo
SubscriberHi everyone.
Is it possible to manually change the temperature in a cell zone in Fluent (2022 R2)?
For example, if I have a rectangular duct 0.5 × 0.5 m, which is 2 m long, and in the middle, there is a zone 0.1 m thick. If I wanted to change the temperature in that zone to, say, 400K and make the downstream air acquire that temperature without using heat suorce, which UDF should I use?
I'm working on this because I want to model an adiabatic cooler, where the temperature changes relative to humidity. For that purpose, I modeled humidifying of the air, however, the last step is to assign a temperature to a cell zone in relevance to humidity.
My idea is to write a code in which I would write something like T = f(RH).
Sincerely
February 27, 2023 at 2:22 pm
Ansys EmployeeIf the zone is bounded by walls you can set the temperature. Otherwise, have a look at the FIX option in the cell zone panel.
3744
2573
1821
1236
594
