April 26, 2021 at 10:55 am
SubscriberI notice there are many broken links since the upgrade to the forum in April 2021.
Below is one example, which came from the last post in this discussion:
https://forum.ansys.com/discussion/3941/hyperelastic-simulation-settings
https://forum.ansys.com/thread/convergence-issues-highly-distorted-elements/?order=all#comment-17ec0560-a744-485b-b8ac-a86500f305d4
I have seen several others and I will return to this discussion each time I find one.
April 27, 2021 at 11:21 pmpeteroznewman
SubscriberBelow is another example of a broken link in this discussion: https://forum.ansys.com/discussion/8569/a-software-execution-error-occurred-inside-the-mesher-the-process-suffered-an-unhandled-exception#latest
https://forum.ansys.com/thread/face-meshing-shell-mode/?order=all#comment-b5805aec-cd48-40ef-8a33-aa8400b3b47b
April 28, 2021 at 4:15 pmRob
Ansys EmployeeOne for to check. ThanksMay 1, 2021 at 11:31 ampeteroznewman
SubscriberThis is one of my best threads!
https://forum.ansys.com/thread/convergence-during-large-deflection-of-hyperelastic-materials/
It linked to this YouTube video:
https://www.youtube.com/watch?v=XCvOyyRJ8rA
Here is another one.
https://forum.ansys.com/thread/modeling-hyperelastics/
May 5, 2021 at 11:33 ampeteroznewman
SubscriberHere is another one found in this discussion: https://forum.ansys.com/discussion/comment/116420#Comment_116420
https://forum.ansys.com/thread/cyclic-elastic-plastic-simulation/?order=all#comment-a4783d7e-ce29-4104-a440-a97b00bcdccf
´╗┐I think that link should land here: https://forum.ansys.com/discussion/3085/cyclic-elastic-plastic-simulation
May 11, 2021 at 12:55 pmpeteroznewman
SubscriberFrom this discussion... https://forum.ansys.com/discussion/1788/how-define-tow-cable-rope-for-elevator-machine-in-ansys-workbench
https://forum.ansys.com/thread/how-to-create-link180-element-in-tension-in-ansys-workbench/
May 14, 2021 at 11:22 pmpeteroznewman
SubscriberFrom this discussion...https://forum.ansys.com/discussion/10879/applying-the-load-in-4-point-bending-test-urgent-please#latest
https://forum.ansys.com/thread/3-point-bending-test-for-different-thickness-of-material-co-polyester-petg/
https://forum.ansys.com/thread/three-point-bending/
https://forum.ansys.com/thread/4-point-bending-test/
https://forum.ansys.com/thread/maximum-load-and-deflection-profile/
May 17, 2021 at 7:48 amRob
Ansys EmployeeThanks it looks like links with hypens in them have failed to migrate correctly.
May 17, 2021 at 3:28 pmmdhiz97
SubscriberThank,all the link for stimulate bending test is still broken.
May 27, 2021 at 12:26 ampeteroznewman
SubscriberJune 5, 2021 at 1:00 ampeteroznewman
SubscriberJune 6, 2021 at 2:12 pmpeteroznewman
Subscribermore broken links found in this discussion: https://forum.ansys.com/discussion/comment/40471#Comment_40471
https://forum.ansys.com/thread/need-help-with-acoustic-simulation/
https://forum.ansys.com/thread/helmholtz-resonator/
June 7, 2021 at 11:47 ampeteroznewman
SubscriberJune 13, 2021 at 8:36 pmpeteroznewman
SubscriberJune 13, 2021 at 10:54 pmpeteroznewman
SubscriberThis first link is broken
https://forum.ansys.com/thread/how-do-i-implement-combin40-for-springs-in-wb
However, I found the following link is NOT broken
https://forum.ansys.com/discussion/1110/how-do-i-implement-combin40-for-springs-in-wb
Rob, you suggested that should check these broken links. I have not heard anything about them. What remedial action is being taken, if any?
June 16, 2021 at 12:47 pmpeteroznewman
SubscriberJune 16, 2021 at 2:29 pmRob
Ansys Employeeapparently the data base didn't fully migrate the threads with hyphens in. Some may have made it but many didn't. We are looking to see if it can be fixed but at present it looks like it could be nearly manual: maybe a job for the interns.... :)
June 30, 2021 at 10:43 pmpeteroznewman
This discussion: https://forum.ansys.com/discussion/12638/shared-topology-vs-contact
has a broken link: https://forum.ansys.com/thread/difference-between-bonded-contact-and-node-merge-1/
and another broken link: https://forum.ansys.com/thread/mesh-matching-on-two-bonded-parts-w-out-shared-topology/
March 4, 2023 at 1:47 pmViewing 18 reply threads- You must be logged in to reply to this topic.
Trending discussions- search does not work.
- Regarding not getting link of click “accepted answer”
- Discussion Creation Error
- unable to open the saved ansys file.
- Access to ANSYS Customer Portal?
- ACP module does not start
- I have a student account and I can’t get my customer number. How I can fix this?
- Ansys Innovation Course Certificate
- How to submit a bug report?
- Images added to Posts are scaled UP and down
7742
4502
2963
1449
1322
