many CEL expressions are not recognised as a variable or expression
    • aqueous5386
      I tried to simulate an unsteady simulation in CFX pre but I get the following error:
      could you help me out this problem
      Error processing expression 'Interface Length Scale'.
      The name 'AIAD Interface Length scale' is not recognised as a variable or expression.
      The name 'AIAD IAD' is not recognised as a variable or expression.
    • rfblumen
      There is definitely something wrong in how one or more expressions are defined.  Unfortunately, there isn't enough information provided to determine the exact issue.  This problem would need to be handled through Ansys Support.
      • aqueous5386
        thanks for your guidance
