February 10, 2021 at 7:56 pm
JustMason
SubscriberHello All,
I am a SysAdmin at a university, and am getting a number of complaints regarding the 2021R1 Ansys install I've deployed to a lab and other places. The Analysis Systems tab of Workbench 2021r1 is missing all components except for SPEOS. Both the 2019r3 and 2021r1 versions that have this variance were installed via ISO images downloaded from the customer portal.
Please let me know if you have any idea what is causing this variance, it's driving me up a wall. 2019r3 on left, 2021r1 on the right. I check all component boxes and spam the next button to install both. Has something changed in the install process I haven't noticed?
Thank you for your help.
February 10, 2021 at 8:00 pmANSYS_MMadore
Ansys EmployeePlease access the ANSYS Licensing Portal and download an updated license which should resolve this issue.nhttps://licensing.ansys.com/index.html#/sslnnAcademic products require new licenses to run 2021 R1 applications as part of our commitment to deliver a simplified, modern licensing experience. Many previous limits are now removed. Read more in 2021 R1 Academic Licensing Highlights.nhttps://download.ansys.com/-/media/customerportal/getting-started/2021-r1-licensing-updates-academic.pdf?la=en&hash=33F5DD9B4043D045079306084FBC811D87233A9CnnPlease let me know if this helps to resolve the issue.nnFebruary 10, 2021 at 8:03 pmJustMason
Subscribermmadore,nnThank you for the fast response, I'll download and apply this license immediately. My license manager is 2020r2, wil that be sufficient for the time being?.Thank you,nn-MasonnFebruary 10, 2021 at 8:09 pmFebruary 10, 2021 at 8:36 pmANSYS_MMadore
Ansys EmployeeMason, if you can update to 2021R1 for the license manager that is recommended. Let me have your ANSYS Account Team reissue the licenses for you and send them over.nnThanksnMattnFebruary 10, 2021 at 8:39 pmANSYS_MMadore
Ansys EmployeeArrayCan you please try checking the Licensing Portal again? If you go to Activate Entitlements you can add your server information and get the updated license file. There was a problem with the records but it has been cleared up. This will probably be faster than getting it from your account team.nnThanksnMattnFebruary 10, 2021 at 10:27 pmJustMason
SubscriberHello Matt, nI think all is well now, I'll attempt to download an updated license tomorrow.nnThank you!nn-MasonnFebruary 22, 2021 at 9:17 pmJustMason
SubscriberArrayHello Matt,nMost functionality is present now on 2021r1 of ANSYS, but the aa_r license is gone, which has crippled Mechanical APDL users. aa_r is present in the prior license file, but absent in the file downloaded from the portal on 2/12. nFebruary 23, 2021 at 1:10 pmANSYS_MMadore
Ansys EmployeeArrayThis is covered in the document of changes. aa_X licenses no longer exist, users need to reset their preferences to begin using the revised license files. For Mechanical APDL users, please have them launch using Mechanical APDL Launcher and they can select the correct ANSYS Mechanical license from the dropdown.nAcademic products require new licenses to run 2021 R1 applications as part of our commitment to deliver a simplified, modern licensing experience. Many previous limits are now removed. Read more in 2021 R1 Academic Licensing Highlights.nhttps://download.ansys.com/-/media/customerportal/getting-started/2021-r1-licensing-updates-academic.pdf?la=en&hash=33F5DD9B4043D045079306084FBC811D87233A9CnViewing 8 reply threads- You must be logged in to reply to this topic.
Trending discussions- License Error
- Workbench not opening
- Workbench error
- Ansys2021R2 ansys212 seg faults immediately on RHEL8.2
5386
3375
2471
1310
1022
