Mapping Data From Fluent to Steady-State Thermal
    • AhmedAbdelrahman
      Hi everyone,
      I am actually trying to map the HTC generated from a fluent model into a steady-state thermal. However, after importing it, the HTC imported on surfaces is zero. I guess this is because I am missing adjusting the intervals on fluent since the source time steps do not appear in steady-state. I do appreciate your help.
      Please see the attached pics for better explanation.
    • Karthik R
      Administrator
      Hello,nCan you show how you are exporting the data from Fluent and reading into Steady State Thermal? Are you using an External Data Transfer?nKarthikn
    • AhmedAbdelrahman
      No, I am not using external data. I am actually connecting the fluent solution to the steady-state setup as shown below. nThat way, it appears like an imported load in steady-state thermal. nn
    • Stephen Orlando
      you can simplify the simulation by modelling the fluid and solid in Fluent. Is that not possible in your case? What is the end goal? To determine temperature in the solid or stress in the solid? or both?n
    • AhmedAbdelrahman
      thanks for your reply. I am actually modeling two different fluids, water (stationary) and air (rotating) inside an electric motor. I tried to simulate both on the same fluid model but it did not work out. Therefore, I have to simulate each one individually and combine them together using the steady-state thermal by importing the Heat transfer coefficients from both models separately. n
Viewing 4 reply threads
