Mapping large data pressure value using external data module
    • mohammedlaminemekhalfia
      Dear ANSYS experts.
      Hope this post will find you well.
      I have a Pressure matrix constitute of 2000*10000 values where each column represent the pressure values at a time step.
      and I have the pressure coordinate (x,y,z) in a seperate file.
      for the pressure values, is there a method to automatically input and prganize them as it is absolutely impossible to do it manually.
      I really appreciate your thoughts.
      yours sicerly
    • Ashish Khemka
      Hi Mohammedlamine,
      What is the issue you are facing when using External Data?
      Ashish Khemka
      @Ashish khemka  I could not transfer the load from fluent to transient structural so instead of that I used external data modele to transfer it but the problem is that I have a lot of data ( a force vector with more than 1000 value ) so how to resolve the issue
