November 13, 2023 at 3:34 pm
Wenlong Zhang
SubscriberWhen using multiphase flow mixture model and component transport model in fluent, why can't I determine the volume fraction of each phase in the multiphase flow inlet when I set the boundary condition of mass flow inlet? In a multiphase flow, the first phase is liquid water and the second phase is wet air, which consists of two components, air and water vapor. I want to set the inlet to be all second phase, i.e., the volume fraction of the second phase is 1, but I can't set the multiphase flow inlet.
November 13, 2023 at 4:49 pm
- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Difference between “total pressure” and “absolute pressure”?
- Drop Test of a Water-Filled Tube
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3151
1680
1470
