Mass Flow Rate setting
    • atul.srivastava216
      i want to ask what is the mass flow rate setting while using pressure swirl atomiser DPM model ? Is it related to the number of streams setting ?
    • Kishan Konannavar
      Hello
      Pleae refer to the following link. Hope it helps.
      20.3. Setting Initial Conditions for the Discrete Phase (ansys.com)
      Thank you
    • Robert Woolhouse
      No, you're setting the total mass flow. The number of streams will determine the initial parcel count, more is good up to the point where it slows the computer down too much.
