March 15, 2021 at 4:34 am
snr1
SubscriberHow to convert the mass flow rate result units from fluent to other?nExample: Fluent gives the mass flow rate value in kg/(m3.s), then how to convert this into kg/s?n -
March 15, 2021 at 8:06 am
Aitor
SubscriberFluent gives the mass flow rate in kg/s. In any case, to convert kg/(m^3*s) to kg/s, just multiply the result by the surface area.n -
March 16, 2021 at 6:00 am
snr1
SubscriberIn UDF, the source term is in units of kg/(m3.s). After the results, how to convert this source term into kg/s?n -
March 16, 2021 at 9:48 am
Aitor
SubscriberWhich source term?n -
March 17, 2021 at 7:03 am
snr1
SubscriberMass source termn -
March 17, 2021 at 12:04 pm
Ansys EmployeeThe source term is applied to a zone in Fluent that has a volume. If we have a zone volume of 1m3 and want to add 1kg/s we have a source of 1kg/m3/s. If the volume is 0.5m3 and we want 1kg/s the source is 2kg/m3/s n -
March 17, 2021 at 4:47 pm
snr1
SubscriberYes, i agree with this. But my point here is: i know the source term values during the simulation in Kg/(m3.s) and now i want convert this into kg/s. How can we do this?. -
March 17, 2021 at 4:55 pm
YasserSelima
Subscribermultiply it by the volumen -
March 18, 2021 at 5:28 am
snr1
SubscriberWhich volume should I consider? because its a multiphase flow simulation.n -
March 18, 2021 at 2:47 pm
Ansys EmployeeThe source is applied to a volume in Fluent. You need to scale the source by THAT VOLUME to get the correct mass into the system. n
Viewing 9 reply threads
Trending discussions
Top Contributors
2524
2066
1285
1096
459
Top Rated Tags
