August 14, 2018 at 3:04 am
Carly
SubscriberHey
I want to convert from mass fraction of a species into PPM in a UDF or custom field function. I saw many define it as mass fraction x 10^6 while others define it as mass fraction x density of mixture x 10^6 / density of species. Would you please let me know which one is correct or if there is another way. Thanks -
August 14, 2018 at 7:51 am
DrAmine
Ansys EmployeeYou need to stick to one of the definitions from the literature: ppm mole or ppm weight or ppm volume or..... All definitions are correct you need to select one which fits your needs. You have to make that decision!
August 14, 2018 at 3:31 pm
Dino
SubscriberIf volume: PPM = mass fraction * density_mix * 10^6 / density_species
If weight: PPM = mass fraction * 10^6
If mole: PPM = mass fraction * 10^6 * MW_mix / MW_species
In UDF: you can access the mass fraction via C_YI(c, t, i) where i is the species index. C_R(c, t) for the density of the mixture. I did not need to call the molecular weight (MW) before so I am not sure how to access it through the UDF. Hope this helps.
December 21, 2020 at 9:58 am
jacklien
SubscriberI suggest to use ppm to percent calculatornn
2524
2066
1279
1096
457
