March 4, 2022 at 9:13 am
marek.wojcik
SubscriberHow to query mass of solid?
Solid has material (with given density) assigned but measure->Mass properties doesn't show mass of the solid in question.
March 4, 2022 at 9:38 am
Devendra Badgujar
Forum Moderator-
March 4, 2022 at 10:08 am
marek.wojcik
SubscriberDevendra Badgujar
It works for a solid as you described. Thank you.
March 4, 2022 at 9:49 am
Devendra Badgujar
Forum ModeratorHi MW
Are you using Discovery Live? The steps I mentioned earlier are for newer versions Discovery.
March 4, 2022 at 10:09 am
marek.wojcik
I use Discovery, the newest.
- How to work with STL file?
- section plane
- material properties
- Coordinates orientation
7646
4468
2957
1427
1322
