Mass transfer from bubbles to liquid
    • carmendecrescenzo90
      I need to simulate the methane   mass transfer  from gas in a bubble to liquid. I believe that species transport mass transport is the most effective way but this error appears "MPI Apllication rank 0 exited before...". I use Eulerian multiphase model
      Can someone help me?
      Thank you in advance
    • Karthik R
      Administrator
      This might be due to your model set-up and solver settings. Your solution is simply not converging. That is the reason why you are seeing this error.
      You will need to provide us information about how you are setting up the model. Also, what is your mesh quality? Do you see this message right after you hit 'Calculate' or after a few time-steps / iterations?
      Thanks.
      Karthik
