mass transfer of Oxygen from air to water with rotating disk
    • cfd1994
      i am modeling 2D unsteady, axisymmetric, incompressible  of  the two-phase flow, comprising air as the gaseous phase, and water as the
      aqueous phase,with  a species transport equation of the oxygen transfer from the gaseous phase to the aqueous phase.
      the impeller is speeding with angular velocity, there is any help to simulate this model ?
      i used VOF model with species and i got a good result of transport  Momentum (streamfunction.....) but im not good in species transport
    • Keyur Kanade
      Please select appropriate category while posting question.
      Moving to fluid dynamics category to get better response.
      Keyur
    • cfd1994
      I choosed fluid dynamic category i didn't understand where is the problem
