January 24, 2023 at 7:46 am
Router
SubscriberHi
Actuell we are back! I becomes since installation 2023R1 this message by transfer from Mastercam to Spaceclaim
Where can i download the newest Files for transfer from Mastercam to Spaceclaim? My last are this see printscreen
Thanks for help
Router
January 24, 2023 at 8:09 am
Subashni Ravichandran
Forum ModeratorHello Router
Let me check on this and get back to you.
January 27, 2023 at 3:13 am
Can you please confirm if you have installed the Add-in and SpaceClaim with Admin rights?
I see that the error shows SpaceClaim 2012. Which version of SpaceClaim are you using?
January 27, 2023 at 3:25 am
Router
SubscriberYes i have admin rights and use SC 2023R1 and SC 2022R2
January 27, 2023 at 4:13 am
Forum ModeratorRouter
Can you please share the latest folder from the below location?
C:Users
AppDataLocalTempSpaceClaim -
January 27, 2023 at 4:37 am
Router
SubscriberHi Subashni
there doesnt exist a Spaceclaim folder! I have a there a Discovery Folder
and a Ansys Folder and a .ansys folder
January 27, 2023 at 4:38 am
Forum ModeratorPlease share the latest folder from Discovery Folder.
January 27, 2023 at 4:48 am
Router
SubscriberSee attached ZIP
January 27, 2023 at 4:50 am
Router
SubscriberBTW When you work at this transfer is it possible that you integrate to existing file formats
X_T, Step and Acis also the orginal scdoc Format as additional in the config File from transfer?
This was very helpfull , while the quality from direct read scdoc in mastercam is much better
January 30, 2023 at 1:14 am
Router
SubscriberThis ate all my ansys folders Did you receive it ?
January 30, 2023 at 1:33 am
Thanks for sharing. Let me check and get back to you
February 3, 2023 at 1:41 am
Router
Any news about ?
- How to work with STL file?
- section plane
- material properties
- Coordinates orientation
7742
4502
2963
1449
1322
