Discovery Import
Discovery Import
Mastercam Addin
    • Router
      Hi Ansys Support
      I have installed the new ANSYS discovery 2020R2;  Also i am using Mastercam CAD CAM where exist a Addin for translate direct in Mastercam over the toolbar from SC to Mastercam; In new Release it doesnt work like in 2020R1,
      it brings a error message Spaceleim  2012 couldnt found!
      Give it a new Add In for Mastercam  and Ansys 2020R2
      Thanks for help
      Router
    • Charudatta Bandgar
      Hello Router ,
      I am looking into it, and will get back to you as soon as possible.
      Charudatta
    • Router
      Hi Charudatta
      Have you any news about this issue
      Thanks for feedback
      Router
        Hello Router ,
        That is unexpected behavior, thanks for bringing that to our notice.
        I have filed a bug report (ID: 310745) to highlight this issue to the developers. I will let you know if there is an update regarding the same.
        Regards.
    • Router
      Hi Charudatta
      Thanks for feedback and log as Bug!  Have you a idea how long we must wait for a fix, and where i can download the fixed files?  Its important, while Mastercam has released the Version 2021, and customer will use this version immediatly in combination with SC
      Router
        Hello Router ,
        I am in conversations with the developers, I will get back to you with the information as soon as possible. Sorry for the inconvenience.
        Regards.
        Hello Router ,
        It appears the MasterCAM addin will need to update its API references in order to work with 2020 R2. The old API version it appears to be based on has been retired in 2020 R2.
        Until this is resolved, you might have to continue using the older version for ANSYS.
        I will keep you posted on any new development regarding this.
        Thanks.
      Hello Router ,
      The MasterCAM addin has been updated and should be working, please check and let me know.
      The internet browsers sometimes cache the links, trying on a different browser or with “incognito mode” should get the right version of the addin.
      Regards.
      • anssi.mustonen
        Charudatta Bandgar
        I downloaded the updated files, but it does not still work?
        How do I ensure that the files are updated?
        And have you any evidence that someone is using MasterCam 2021 addin and SpaceClaim 2020R2 ;), some video would be nice ;).
        Any idea to solve this problem?
        Hello Anssi
        The files are updated and verified on developers' and customers' end.
        I will still get in touch with the developers to check if I can help you any better.
        Regards.
      • anssi.mustonen
        Hi Charudatta Bandgar
        Ok, thanks! Will do some test here also.
    • anssi.mustonen
      So where can we download the working MasterCam add-in version?
Viewing 5 reply threads
