October 18, 2023 at 5:13 am
hansenli
SubscriberHi,
I received this error when I tried to use MAT295 for an SPH section:
Error 30281 (INI+281)
SPH initialization
Material number 1
material type 295 is not implementedIs that this model is not compatible with SPH section? Do you have other methods to incooperate the volumetric effect into a hyperelastic model for bio related material?
Thanks!
October 18, 2023 at 2:15 pm
Ram Gopisetti
Ansys EmployeeHi Hansenli,
Check the following link for compatible material model for SPH
https://lsdyna.ansys.com/dynamat/
*MAT_176 can be the potential candidate.
Cheers, Ram
October 18, 2023 at 3:41 pm
Jim Day
Ansys EmployeeHyperelastic materials and SPH typically don’t go together very well. SPH suffers from tensile instability, which means the material will have a tendency to break apart instead of deforming in tension. And as Ram mentioned, dynamat (based on information at the beginning of the *MAT section of the LS-DYNA User's Manual) indicates that SPH can't be used for MAT_295. If you're intent on using MAT_295, you could instead try EFG or SPG. -
October 19, 2023 at 4:12 am
hansenli
SubscriberThank you for your advice! SPG cannot be used for MAT_295 either. Is there an update about this in the latest version. We are currently using R12 version.
October 19, 2023 at 2:44 pm
Jim Day
Ansys EmployeeI'm unable to say with any certainty. To best answer that question, download version R14.0.0 and try it.
- Maximum Time Step
- Error 20211 (STR+211) while 2D impact analysis
- ls dyna has no solver
- LS-Dyna Prestressed
- Whereabouts of the LS-DYNA program manager
- License error : NO SUITABLE FEATURE FOUND
- Total Contact Force and Contact Pressure
- Contact not working in Ls-Dyna and Ls-Dyna ACT (WB)
- Element direction..
- TIED_CONTACT for Shell Elements – Gap between Shell-Shell and Shell-Solid
8808
4658
3153
1680
1470
