March 14, 2022 at 1:15 am
FluxLimited
SubscriberI am getting the following error:
The part with ID 1, material ID 1, has a material type 8 that is invalid for 4-node shell elements.
Is there a 2D element formulation that will work with *MAT_008 (High Explosive Burn)?
March 14, 2022 at 3:32 pmtslavik
Ansys EmployeeA 2D continuum formulation must be selected. Please set ELFORM= 13, 14 or 15 in *SECTION_SHELL.
Trending discussions- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
2616
2098
1323
1108
461
