Match control in Fluent meshing
  • fatemeh.hosseini
    Many Thanks Keyur.
    I tried to use the method on the video but the error occurs.
    The geometry is a tube that I want to use periodic boundary condition for inlet and outlet. (So it is not a rotational periodic boundary condition,it is transnational.)
    The screen shot of the error has been attached.
    Regards Fatemeh
  • Keyur Kanade
    Make sure your geometry is topologically periodic. Also if automatic is not working, try manual option.
    6.2.5. Setting Up Periodic Boundaries (ansys.com)
    Regards Keyur
  • Viewing 3 reply threads
