March 25, 2022 at 10:19 am
Medri17
SubscriberHi , im actually working on crash simu for my final project , i took the car model from a site , its verified by gwa ,can i know wich material is used just by looking at its parameters ?
for example for the back rail
March 25, 2022 at 8:56 pmMarch 25, 2022 at 9:55 pmMedri17
Subscriberhi @AndreasKoutras , well im looking for each part's strain failure , and for that i need to know wich material is used , like is it STEEL CARBON, Alu etc And for this example i was wondering if i could know with material is used on this rail
Thanks a lot for the response !
March 25, 2022 at 10:08 pmAndreas Koutras
Ansys EmployeeYou mean you want to know to what kind of actual material the material properties specified in the input correspond. There is no such information passed in the LS-DYNA input.
March 25, 2022 at 10:12 pmAndreas Koutras
Ansys EmployeeYou need to ask the one who created the input or find some documentation behind the input. You can also try opening the keyword file with a text editor and see if there are any useful comments in there.
March 25, 2022 at 10:40 pmMedri17
Subscriberok thanks a lot ima try and figure it out :/ .
March 25, 2022 at 10:41 pmViewing 6 reply threads- You must be logged in to reply to this topic.
Trending discussions- Explicit dynamics ERRORS
- explicit dynamics
- turning simulation
- Monte Carlo Simulation
- How to solve Energy error too large
7742
4502
2963
1449
1322
