August 28, 2018 at 12:30 pm
androhandball
SubscriberI accidentally delete the material (air and water). So is it possible to restore it because now I can't run the flow simulation and my ansys discovery immediately shut down after I click on create solution
August 28, 2018 at 2:35 pm
Naresh Patre
Ansys EmployeeHello RITEH12
Go to %AppData%RoamingSpaceClaim and rename "Discovery" folder to "Discovery_old" and launch Discovery Live again.
August 28, 2018 at 3:13 pm
androhandball
SubscriberHello Naresh Patre
Thank you for your answer but now when I change the name of that folder I can't even open the ansys discovery because I get an error message like: windows is finding SpaceClaim.exe
And if I want to find it myself than when I go to roaming map there is no such a map.
So now I don't now what to do.I even try to uninstall and install again, without my antivirus and everything is the same.
August 28, 2018 at 3:29 pm
Naresh Patre
Ansys EmployeeRITEH12 Are you sure you renamed "Discovery" folder to "Discovery_old"? This folder is located in C:Users
AppDataRoamingSpaceClaim. This "Discovery" folder contains another folder named "MaterialLibrary" which inturn hosts an xml file with material data from your current session. So by renaming the "Discovery" folder, we are trying to clear this material data. Secondly, while reinstalling, did you install in admin mode?
August 28, 2018 at 3:38 pm
androhandball
SubscriberNaresh Patre yes I install in admin mode and I rename the map like you said.
But after that I try to open the Ansys discovery with my shortcut on the desktop and it gave me that error I mentioned before.
After that computer found the map and fix it by himself but I still can't run the simulation because there is no material a could choose.
August 28, 2018 at 4:14 pm
Naresh Patre
Ansys EmployeeRITEH12 That's a bit strange! When I deleted "Water' material, I was able to bring it back successfully by renaming the "Discovery" folder.
Can you try creating a new "Water" material using below material properties and see if you can use it?
Alternatively, you can also find the material properties for water in MaterialLibrary.xml located at
ANSYS Incv191scdmMaterialLibrary. -
August 28, 2018 at 4:32 pm
androhandball
SubscriberNaresh Patre thank you very much.
Now I open structural simulation and than I add material over there.
After that Ansys recognize Air when I run flow simulation.
Thank you again.
Best regards!
- loss of user settings
- Ansys Discovery Modeler vs Spaceclaim speed
- pressure
- Annotation font color
- Copy user settings to new release
- Can’t see license on online account
- ANSYSLI Exited or could not read server port ANSYSLI_FNE_PORT
- help online
- Python Script: graphical interface
- Unexpected graphics error
5454
3419
2473
1310
1022
