TAGGED: designpoints, parametric-analysis, structural
December 4, 2020 at 6:33 am
BradFB
SubscriberHello all,nIm running a parametric study in Ansys WB, each time the geometry is updated for each design point, the material assignment is wiped and I get the following message: 'The Model component in Static Structural for design point 1 requires user input before it can be updated'.nWhy is this happening? nAlso, I dont want automatic connections to be created, is there a way to avoid this for each design point?nThanks,nBrandom F.n -
December 4, 2020 at 4:21 pm
KR
AdministratorHello,nEach time a geometry is created in your case, you have the same consistent number of parts in your geometry? If this is not the case, I can see why the tool would ask you to assign materials each design point. It is an important step in your parametric run to ensure that changing your parameters does not break / change the overall workflow. nI hope this helps.nThanks.nKarthikn
- A solver pivot warning or error has been detected
8788
4658
3151
1680
1470
