Tagged: Lumerical-FDTD, memory-report, simulation-report, warnings
December 8, 2021 at 4:34 pm
photon
SubscriberIn the simulation and memory report in FDTD, I am receiving the warnings as below:
December 9, 2021 at 12:42 amGuilin Sun
Ansys EmployeeThis might be the 2nd report of this issue however we have not duplicated this.
Please check the material fitting and make sure the fitting range is the source bandwidth; and make sure the FDTD settings are not modified accidently. Suggestions:
1: open a new project file, copy and paste all the objects excluding FDTD by Ctrl^C and Ctrl^V, add FDTD and modify the xyz spans accordingly, and boundary conditions only, then test to see if it disappears
2: simplify the simulation file with two materials: Au and SiO2, and test. if problem still exists, please give your settings so I can test, in particular the source setting (spectrum), material fittings and FDTD Advanced settings
January 16, 2022 at 2:39 pmspacelover17
SubscriberI was having the same issue. What settings would you like to see? I could also email you my simulation file itself, tested with the two suggestions you provided.
January 17, 2022 at 4:56 pmGuilin Sun
Ansys EmployeePlease just check the actual material fitting. As long as it is the same range as you set, it should not affect the final result. Yes, please send us a email if you can.
March 20, 2022 at 9:17 amMarch 21, 2022 at 10:19 pmGuilin Sun
Ansys EmployeeFirst please check the source wavelength range and see if they agree. Occasionally this may happen for certain machines. But as long as the fitting is correct, it should not affect the result. If this happens again, please let us know your computer OS version.
BTW: we are not allowed to download customer files in this forum. But my test did not show this issue:
March 24, 2022 at 9:06 amamnonjw
SubscriberHi I see that you're using version 2022 R1.1. Can it be that there was a bug fix sometime between 2021-R2.5 and 2022-R1.1?
I went over the release notes and didn't find anything about changes to the material fitting.
This is the global source wavelength range (the simulation I uploaded doesn't override the global settings)
March 24, 2022 at 3:34 pmGuilin Sun
Ansys EmployeeThere is no such bug report so even if there is a fix it is not intended. Please try the newest version. Actually I tested other versions when some customers reported this before.
Viewing 7 reply threads- You must be logged in to reply to this topic.
- Error on Lumerical device
2524
2066
1279
1096
457
