March 10, 2022 at 3:26 pm
ansysuser123
SubscriberHello,
I unsuppressed a solid body in SpaceClaim and extracted a beam from it. When I update in Mechanical, random components lose their material assignments in addition previously defined contact pair lose their scoping. I do have Auto Generate contact set to No. and the topology is not shared in SpaceClaim.
any advice would be greatly appreciated.
Mike
March 11, 2022 at 12:50 pmAniket
Ansys EmployeeDid you set "compare parts on update" (in the property of the geometry on the workbench page) to Associatively, before importing it the first time? If not kindly do that and set up the model again, next time you change anything in SpaceClaim only contacts and materials assigned to that body will need to be reassigned.
https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v212/en/ref_cad/cadComparePartsOnUpdate.html
In case you don't have this option set, and it was to default No, still you can use the Model assembly method to assemble your old model and the new model (sans old unchanged parts).
https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v212/en/wb_sim/ds_mesh_mod_examples.html
-Aniket
2706
2146
1357
1144
462
