June 17, 2023 at 7:43 am
Zaid Abd Al-Hadi
SubscriberHey
is it applicable in MAPDL to define two individual materials (fiber and matrix) then APDL itself can produce the resulting lamina
and use it as the material definition in the section command? if yes, how to do this?
best regards, -
June 20, 2023 at 2:54 pm
Ashish Kumar
Forum ModeratorHi,
I am not sure if this example might be of help to you:
How to access the ANSYS Online Help
Ashish Khemka
June 21, 2023 at 3:38 am
Zaid Abd Al-Hadi
SubscriberThanks!
June 20, 2023 at 3:12 pm
Govindan Nagappan
Ansys EmployeeYou can use Material Designer tool in Workbench and compute the Lamina properties from Fiber and Matrix properties you have. Then you can pass the properties to Mechanical or use it in Mechanical APDL. For doc check here: Ansys Product Help
June 21, 2023 at 3:44 am
Zaid Abd Al-Hadi
SubscriberThank you!
- check element type
- Meshing Error
- Error in meshing
- How to resolve Mesh Failure
7742
4502
2969
1449
1322
