August 13, 2019 at 1:23 pm
viv123
SubscriberHello,
When I am running Material designer in Ansys workbench, everything is going fine but when I am solving to get results in Material Designer it is showing "Could not connect to SolverProxy".
I am also enclosing screenshot please check.
Thank you!
Regards
August 13, 2019 at 7:50 pm
Sandeep Medikonda
Ansys EmployeeI've seen this problem once before. In that case, the problem was to down to a space in the Windows username. This caused problems when calling files from AppData (C:Users
AppData LocalTemp). The problem has been corrected in 2019 R2. So either upgrade or check your windows username once.... -
August 14, 2019 at 3:52 am
viv123
SubscriberHello SandeepMedikonda Ji,
My version is already 2019 R2. Now what should I check as window user name.
Thank you
Regards
August 14, 2019 at 1:08 pm
viv123
Thank you
Regards
August 15, 2019 at 12:59 am
Sandeep Medikonda
Ansys EmployeeOk, what is your windows user name?
You can check it as discussed here:
https://help.logmein.com/articles/en_US/FAQ/How-do-I-find-my-Windows-username-en1 -
August 15, 2019 at 6:12 am
August 15, 2019 at 7:55 pm
Sandeep Medikonda
Ansys EmployeeI think that is where the problem is, try to avoid special characters such as '-' or '' in the username.
August 16, 2019 at 9:58 am
viv123
SubscriberOk Thank you, sir, I check.
August 16, 2019 at 1:41 pm
Sandeep Medikonda
Ansys EmployeeI heard back from one of our developers on this and this is what they had to say:
One of the methods for retrieving the username gives you “DOMAINusername”. I am not sure whether the entry provided means “desktop-gd8d0j3ismela user” or “desktop-gd8d0j3ismela”. Both cases should be covered in 2019 R2 so I’d be surprised if this is the issue.
The student should check where the temp directory leads to. To access the temp directory enter ”%temp%” into the address line of the Windows Explorer. Then you can copy the absolute path back out again.
A second thing to check is whether the process DSSolverProxy2.exe is started.
Also read-write access to the temp directory could be an issue. Although this is unlikely.
August 16, 2019 at 8:00 pm
viv123
SubscriberOk SandeepMedikonda sir, I check this,
Meanwhile, I run the Material Designer in my friends Pc there it runs fine but with user-defined Rve it is not giving any result output result is just Nan and 0,
I took the dimension is in micro for both space claim.
So now what should do to get the result.
Thank you
Regards
August 20, 2019 at 3:20 pm
Sandeep Medikonda
Ansys EmployeeThere is a specific tutorial on User defined RVEs in the help.
I would recommend following it step by step and see if you are able to produce any results. This should give you more insight into the procedure and you can use that experience to compare what you are doing wrong in your particular case.
It is possible that you are working with a complicated geometry and material designer is not able to successfully carry out the analysis. i.e., force reactions are not being predicted, NaN is typically output in such cases.
August 21, 2019 at 7:23 am
viv123
SubscriberDear SandeepMedikonda Ji,
I tried again from my Pc with unidirectional RVE but the message is coming could not connect to slover proxy, i am sending the error message to you. Everything is working till setting but at the time of analysis run for results this message is coming.
August 21, 2019 at 11:48 am
Sandeep Medikonda
Ansys EmployeeWhich school are you from? Please reach out to the account manager or Ansys Support Coordinator (ASC) at your school and request them to escalate this to ANSYS technical support.
August 23, 2019 at 6:06 am
viv123
Ok I will discuss them too but other modules are working fine like static transient(structural,thermal) etc.
Only the problem in Analysis of Material modeler.
Best Regards
August 23, 2019 at 6:10 am
viv123
SubscriberDSSolverProxy2.exe how can this check maybe this is problem
August 27, 2019 at 7:25 pm
chethan89
SubscriberWhere and how to download Material designer. Is it available in student version? i am using latest R2
2110
1335
1110
461
