July 10, 2023 at 8:27 pm
Marissa Jacovich
SubscriberHello,
Can the Material Designer module be used to find the homogenized properties of an imported RVE that patterns in X and Y directions, but not in Z? For example, a single layer corrugated sheet.
Thanks for your help.
July 12, 2023 at 12:16 pm
John Doyle
Ansys EmployeeThe Material Designer Docs do not list corrugated sheet as an RVE model type option, in particular. However, there is a "honeycomb" option - described as consisting of cells with hexagonal shape repeated in two dimensions. Would that work? See Section 2.1.8 of the Material Designer User's Guide.
July 12, 2023 at 1:26 pm
Marissa Jacovich
SubscriberHi John. No, this would not work. A honeycomb RVE is a valid pattern in 3 axes. A corrugated sheet, only two. There is an option for woven composites, so theoretically Material Designer knows how to handle repeating in two dimensions - I just haven't found a way to toggle this ability with a user-defined RVE.
- Invalid Assignment error
- How do I make a chart with multiple material parameters on y-axis?
- *LOCAL COORDINATE SYSTEM ANSYS APDL ? how Ansys transform coordinates system?
- Material library
- PLA Material
- How to add SN curve for new material in Fatigue analysis?
- ANSYS 19.0 with Additive Manufacturing Extension
- properties of balsa wood
- Looking for Spring steel (55Si7) library material
- About Bilinear Isotropic Hardening Plastic Model !
7742
4502
2963
1449
1322
