May 10, 2023 at 1:22 pm
May 11, 2023 at 11:46 am
Ashish Khemka
Ansys EmployeeHi Suren,
Please see if the following post is of help to you:
Changing RVEs size in Material Designer (ansys.com)
Ashish Khemka
May 13, 2023 at 8:29 am
Suren Malumyan
SubscriberThank you for the response,
I saw the post offered , but my question refers to the thickness of fiber, not to the diameter.
Is it possible to model hollow fibers? -
May 15, 2023 at 9:39 am
David Mercier
Ansys EmployeeHi, you may have to use the user-defined RVE: https://ansyskm.ansys.com/forums/topic/ansys-material-designer-user-defined-rves-representative-volume-elements/
May 15, 2023 at 11:42 am
Suren Malumyan
SubscriberHi, the link is not referring to my question.
Please, can you see the above mentioned figure?
Thank you very much.
May 15, 2023 at 11:43 am
David Mercier
Ansys EmployeeIt is possible to define hollow fibers but with you rown RVE (ie user defined method).
- How do I make a chart with multiple material parameters on y-axis?
- Invalid Assignment error
- *LOCAL COORDINATE SYSTEM ANSYS APDL ? how Ansys transform coordinates system?
- Material library
- PLA Material
- How to add SN curve for new material in Fatigue analysis?
- ANSYS 19.0 with Additive Manufacturing Extension
- properties of balsa wood
- Looking for Spring steel (55Si7) library material
- Ansys material damage
5162
3275
2453
