February 19, 2022 at 10:45 pm
noumanzia
SubscriberHi,
I am running a script to change the wavelength range of material explorer, in the main body of my script file. I note that the script does not change the material setting when I run in the main body, but it works fine when it's run separately in script prompt or by calling this script as a function. Otherwise there is no error
Is there any point I am missing here?
setmaterial("my_material","specify fit range",1);
setmaterial("my_material", "wavelength min", 2.0e-6);
setmaterial("my_material", "wavelength max", 2.5e-6);
February 22, 2022 at 10:59 pmGuilin Sun
Ansys EmployeeI am not sure what the error massage you got in the main body of the script: did you create this material before this section of script? or such material "my_material" exists ?
- Error on Lumerical device
2524
2066
1279
1096
457
