April 25, 2023 at 11:12 am
Bill Tapp
SubscriberHey everyone,
I am struggling with the transition from Explicit Dynamic to LS DYNA. I am conducting a numerical study on FOPS structures to create a set of formulas. I am struggling with allowing material failure on the latest full version of this program(2023). How do i actually enable material failure? I am using non linear materials at very high velocities and they destroy it on Explicit Dynamic but on LS DYNA do not.
Cheers for your time
Bill
April 25, 2023 at 2:00 pm
Armin_A
SubscriberHi Bill,
Did you use any failure criteria within the Autodyn (explicit dynamic)?
As far as I know, Autodyn automatically deletes elements once a strain limit is reached (provided that this option is not disabled by the user).
In Workbench LS-DYNA, when you open Engineering Data, there are several failure models available under the Toolbox. In addition, check the MAT_ADD_EROSION under LS-DYNA External Model-MAT (also available under the Toolbox) which serves to erode or delete elements once a certain criterion is met.
- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
5162
3251
2443
