December 3, 2017 at 4:12 pm
Avadhoot
SubscriberHi all. I want to analyse some CAD models which I am going to 3D print. Can anyone please help me figure out how can I assign best possible material for a PLA plastic material used in 3D printing -
December 3, 2017 at 9:04 pm
SubscriberThe attached pdf has the material properties of PLA that you need.
If you want help deciding which values to use, just ask.
PLA is not recommended for parts that require mechanical strength.
Do you have access to any other materials?
If so, why did you choose PLA over some other material?
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2656
2116
1337
1118
461
