TAGGED: custom-materials, engineering-data, gear, transient-structural
January 31, 2023 at 1:59 pm
Aneh
SubscriberI want to simulate a gear pair in ANSYS transient structural for a custom carburising steel, that is not available in ANSYS material database by default. I need to search for the material properties and add them in ANSYS engineering data. My final task is to perform fatigue analysis (for crack propagation) and there will be some large deformation (plasticity)..
I want to know which material properties I should search for. There will not be thermal analysis as I will be working with ambient temperature only. It was mentioned in another thread that atleast density, isotropic elasticity should be mentioned for a dynamic analysis. But, if large deflections are expected, should plasticity models be also used? If yes, which ones? What other properties/ models/ material laws should be available in engineering data, if I want to perform simulation to find tooth deformation of gear, mesh force, crack propagation etc?
February 1, 2023 at 2:14 pm
Ram Gopisetti
Ansys EmployeeHi, any of the echanical design data book will have this material properties, and you need paris law constants for crack propagation using SMART feature, i would suggest you to look into literature for detail information on these material constants.
Cheers, Ram
- How do I make a chart with multiple material parameters on y-axis?
- Invalid Assignment error
- *LOCAL COORDINATE SYSTEM ANSYS APDL ? how Ansys transform coordinates system?
- Material library
- PLA Material
- How to add SN curve for new material in Fatigue analysis?
- ANSYS 19.0 with Additive Manufacturing Extension
- properties of balsa wood
- Looking for Spring steel (55Si7) library material
- Ansys material damage
5290
3311
2471
