LS Dyna
LS Dyna
Topics relate to LS-DYNA, Autodyn, Explicit STR and more
Material model for non-newtonian fluid
    • cs11
      Hello, I want to model fresh concrete as a Bingham/Herschel-Bulkley fluid using SPH method in Ansys-LS-DYNA. It'd be the best if I can input a loading curve of shear stress vs shear rate for the material model, or a combo of yield stress vs time and viscosity vs time. I was unable to find the exact material model compatible with SPH to use [I checked the material selector tool]. I was wondering if you can share some insights of alternative material models I can use? If fresh concrete specific models are unavailable, is there a generalized non-newtonian fluid model I can use? Am I able to customize a material model? Thank you!
    • Ram Gopisetti
      Hi
      Based on the element formulations, The best model for Non-Newtonian fluid will be the *MAT_SPH_VISCOUS, also check the *MAT_ALE_VISCOUS too if you want to adapt ALE
      Cheers, Ram
    • cs11
      Hello Ram,
      Thank you for your reply. I checked the MAT_SPH_VISCOUS and I found it does not support inputting yield stress - quote from material manual "This material since it is based on the null material has no yield strength and behaves in a fluid-like manner."
      Yield stress is an essential to the concrete material behavior I need to simulate. Again, I need both yield stress and viscosity to be defined in the material model. Could you suggest some alternatives in this regard? Thanks!
