January 20, 2023 at 7:03 pm
sagar.gupta.satrasala
SubscriberHi,
I am conducting a parameter study using Optislang. I have parameterized geometry and material properties as inputs. I have 3 different materials and 9 inputs are parameterized from each material. I can see all the material inputs in the Ansys parameter tab but when I use optislang I can see only 9 inputs from one material and cannot see the material inputs from other two materials. Could someone please tell me the reason behind it and help me solve it?
Thank you in advance!!!
January 26, 2023 at 10:44 am
Martin Husek
Ansys EmployeeHello Sagar,
Could you please give us more details about your workflow to help us understand where the problem might be? Could you please answer the following:- Are you assigning materials in the geometry preparation tool (SpaceClaim, Discovery) or are you using materials from Ansys Workbench?
- Are you using optiSLang standalone or optiSLang in Ansys Workbench?
- What version of Ansys are you using?
Any screenshots of your workflow, parameter tables, scripts are welcome.Thank you,
Martin - Are you assigning materials in the geometry preparation tool (SpaceClaim, Discovery) or are you using materials from Ansys Workbench?
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2726
2156
1359
1150
462
