May 22, 2022 at 6:26 am
Yoker
SubscriberHello Team I want to create a new mechanical constitutive of materials though USERMAT. Under the constitutive, machanical properties of material will change with concentration field. See the simple fomula below:
σ = (1-C)Dε
where C is the normalized concentration, D is the elastic stress-strain matrix.
Perform the structure-diffusion analysis though PLANE223 coupled-field solid element, so we can get the concentration data of each nodes and elements. My question is how can I import the CONC data into USERMAT? I have tried subroutine "emsget" but failed. Maybe it is because I did not code it correctly.
Thanks for your help!
May 31, 2022 at 1:51 pm
David Weed
Ansys Employee, I don't believe that this is currently supported. I'm checking on this and will follow up soon.
June 1, 2022 at 11:13 am
Yoker
Subscriberthanks for your attention. I supposed it is very similar to the situation that Young's modulus changes with temperature and in many cases temperature is non-uniform. I think there should be an approach that can replace the temperature field to other field variables (such as concentration field, current field, magnetic field or radiation field and so on).
July 1, 2022 at 3:06 pm
David Weed
Ansys EmployeeHi Yoker, in speaking with development again, they asked the following:
Do you know if this stress equation below is the only modification the user wants to make to the standard constitutive model? Does this stress affect anything else in the structural part of the model?
December 7, 2022 at 9:49 am
manuel.petersmann
SubscriberHi Yoker,
For what you are trying to do, it should be sufficient to use field-dependent data (TBFIELD + TBDATA) and then define a linear dependence there directly.
BR, Manuel
- How do I make a chart with multiple material parameters on y-axis?
- Invalid Assignment error
- *LOCAL COORDINATE SYSTEM ANSYS APDL ? how Ansys transform coordinates system?
- Material library
- PLA Material
- ANSYS 19.0 with Additive Manufacturing Extension
- How to add SN curve for new material in Fatigue analysis?
- properties of balsa wood
- Looking for Spring steel (55Si7) library material
- Ansys material damage
3870
2639
1859
1262
606
