December 22, 2022 at 6:32 pm
Oskar Kuczek
SubscriberHello, I am performing a 2d effort analysis during orthogonal turning, the analysis runs correctly on materials from the ansys program libraries, but when I try to assign my own material on which the analysis should take place, the program does not perform the analysis correctly, could you help me how to define my material for the analysis to run correctly ? My material is 11SMn30 steel. Regards
December 23, 2022 at 5:36 am
bhagwantP
Ansys EmployeeHello Oskar Kuczek,
Will you please share some more information about material properties you have defined for the material, details of error messsage.
When you say: it runs correctly on materials from the ansys program libraries, does it mean you are taking defalut material from librabry?
Thanks,
December 27, 2022 at 4:32 pm
Oskar Kuczek
Subscriber-
December 28, 2022 at 6:04 am
bhagwantP
Ansys EmployeeHello Oskar,
You can define a path which is scoped to this line and postprocess results for this path.
In scoping method instead of geometry choose path while postprocessing stress.
Thanks
December 28, 2022 at 11:28 am
bhagwantP
Ansys EmployeeGlad to know that initial issue mentioned in post has resolved.
Thanks
- Invalid Assignment error
- How do I make a chart with multiple material parameters on y-axis?
- *LOCAL COORDINATE SYSTEM ANSYS APDL ? how Ansys transform coordinates system?
- Material library
- PLA Material
- ANSYS 19.0 with Additive Manufacturing Extension
- How to add SN curve for new material in Fatigue analysis?
- Looking for Spring steel (55Si7) library material
- properties of balsa wood
- Ansys material damage
2524
2066
1279
1096
457
