Discovery Import
Discovery Import
Material Properties management in Discovery
    • luca
      I experienced Discovery not saving correctly my custom material properties when I enter properties in MPa rather than Pa. This resulted with multiple entries with a Tool icon, which I can not delete.
      Is there a way to browse my material library and edit names, data, duplicate or delete entries?
      Thanks
    • Naresh Patre
      Hello Luca
      Let me look into it and get back to you.
    • Naresh Patre
      Hello Luca
      Please check out below section from the help document on handling user defined materials in Discovery.
      https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v211/en/discovery/UDA/user_manual/materials/topics/c_mat_userdefined.html
    • luca
      Hi Naresh Patre , thank you for your reply.
      I did checked this help document already but did not resolved my issue:
      - custom materials are not saved correctly when I set data in Mpa rather than Pa
      - I still get many entries with a tool icon which I can not delete.
      - What does tool icon means?
      Please see the screenshot posted above,
      Thanks!
    • Naresh Patre
      Hello Luca
      Ok, thanks for your reply. I thought about first mentioning about the help content. Let me look into it and get back to you shortly.
    • Naresh Patre
      Hello Luca
      There doesn't seem any direct option to delete the user defined materials. However, you can edit their names from the option shown below:
      I will be submitting a request to the development team for providing options for managing materials.
Viewing 5 reply threads
