Tagged: fluent, fluid, material-properties-addin, multiphase, udf-fluent
March 9, 2021 at 2:36 pm
anassohail
SubscriberCan we enter the properties of water at two different pressures at varying temperatures in FLUENT?nI am working on a problem in which there are two different streams of fluid at two different pressure and one stream will undergo a phase change. nFLUENT allows the user to enter properties only in terms of temperature by using piecewise linear. nIs there a way where I can specify it with respect to pressure and temperature?. -
March 11, 2021 at 6:41 pm
Surya Deb
Ansys EmployeeHello, nYes. you can use DEFINE_PROPERTY UDF to customize your material properties.nBe careful about Density. For compressible liquid, if you want to vary the density with pressure, then you will need to provide a UDF for speed of sound as well. The link below explains this UDF in more details.nRegards,nSDn
Trending discussions
Top Contributors
2534
2066
1285
1104
459
Top Rated Tags
