3D Design
3D Design
Material removal rate
    • Aads99
      how to simulate the material removal rate for abrasive water jet machining operation?nplease guide me for the same.nthank you!n
    • Ashish Khemka
      nnYou can refer some external links like:nnnRegards,nAshish Khemkan
    • ramgopisetti
      You can achive this using the DEM-LAG coupling or SPH-DEM coupling but it requried your exterties on using the LSDYNA n
