TAGGED: fluent, heat-transfer, msmd-battery-model, udf-fluent
May 16, 2022 at 6:27 am
Chinmay19
SubscriberHello,
I am trying to simulate a cylindrical li-ion cell (26650 LCO) using Ansys fluent battery models. I have a positive tab of aluminium and a negative tab of steel, can anyone guide me on how to define material for the active zone (LCO).
Your insights will be of great help
Regards
Chinmaya
May 16, 2022 at 1:02 pmRK
Ansys EmployeeHello Chinmaya,
Please see the battery modeling tutorials, they'll give you an idea on how to define materials : Chapter 27: Simulating a Single Battery Cell Using the MSMD Battery Model (ansys.com)
November 9, 2022 at 10:32 amArman Burkitbayev
SubscriberHow did you parametrize the msmd cylindrical cell battery?
Viewing 2 reply threads- The topic ‘Material selection in battery modelling using ansys fluent’ is closed to new replies.
Trending discussions- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Drop Test of a Water-Filled Tube
- Difference between “total pressure” and “absolute pressure”?
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3153
1688
1478
