Material with invalid equation of state assigned to Part 1.
    • jiahao
      I am using the explicit dynamics to model the large deformation of a surface model. The material is based on Mooney-Rivlin 5 Parameters model, as shown bellow:
      When I start the solving process, it just stops immediately with problem "Material with invalid equation of state assigned to Part 1.". However, when i use static mechanical to solve the problem, there is no problem. I am wondering whether this model is applicable for surface body in explicit dynamics? Thanks,
    • jj77
      The user manual (explicit dynamics) says that Hyperelastic material only work with 3D parts not with surface bodies.
