Material with linear material properties becomes nonlinear
    • helen.durand
      I am currently running a transient structural simulation where I create a linear material (material 25) and two nonlinear materials (material 30 and 50) using an APDL command object in the prep phase. I am trying to switch from the linear material to one of the nonlinear materials, but I am getting warnings saying that material 25 is nonlinear:
       *** FATAL ***                           CP =     385.078   TIME= 20:27:25
       Change a nonlinear material model, 25, to another nonlinear material
       model, 50, is not allowed for element type 186.
       The above error is non-recoverable by ANSYS
        ANSYS run terminated by the indicated error
        Current data base saved if possible.
      For the linear material, I am using the following APDL inserted into a command block in transient structural:
      MP,KXX,25,15,
      MP,DENS,25,5e3,
      MP,EX,25,5e10,
      MP,C,25,300,
      MP,ENTH,25,5e9,
      MP,NUXY,25,0.3,
      I am aware that it is not possible to switch betweeen nonlinear materials, but I do not understand why it is saying material 25 is nonlinear. Why might material 25 become nonlinear?
      Thank you!
    • peteroznewman
      Hello Helen,
      I can't answer your question, but I have some questions for you. Are you trying to switch materials in the middle of the simulation? Why do you need to switch from a linear material to a nonlinear material during the simulation? Why not begin the simulation with the nonlinear material?
      I have used temperature dependent properties for a material. That single material definition then works over a wide temperature range and Ansys automatically interpolates the correct value from the table at each time step in the simulation.
