February 7, 2022 at 12:34 pm
Vihakha
SubscriberHello,
I'm looking for a very specific material- 40% Carbon Fibre reinforced PP composite, but I can't find it under the Level 3 Advanced Composites section. Could you please help me locate this material or anything similar to it?
Many Thanks,
Vishakha
February 8, 2022 at 2:17 pmDavid Mercier
Ansys EmployeeHi Vishakha What do you mean by Level 3 Advanced Composites section? The Level 3 Aerospace of EduPack?
If you use the search option, here a screenshot of what you get if you look for reinforced PP with carbon fiber (see below).
There is only a record for the 10% carbon fiber one. I think you should use the Synthesizer tool to estimate the properties of the 40% one.
Here a link with more details about the Synthesizer : https://forum.ansys.com/discussion/comment/125177#Comment_125177
February 8, 2022 at 4:38 pmVihakha
SubscriberThank you so much for your answer. What I mean is- I couldn't find it under the composites section, do you have any carbon fiber reinforced PP composites available under it? When I clicked on composites, I could see that there are glass reinforced composites available.
I found the 10% carbon fiber, I'll try using the synthesizer tool.
Thanks again!
February 8, 2022 at 5:53 pmFebruary 8, 2022 at 6:20 pmVihakha
Thanks so much!!
March 17, 2022 at 2:07 pmDavid Mercier
Ansys EmployeeIt's a matter of classifcation. Of course a reinforced polymer can be seen as a composite, but in our case we prefer to keep it in the polymer section. Cheers
Viewing 5 reply threads- You must be logged in to reply to this topic.
Trending discussions- Invalid Assignment error
- How do I make a chart with multiple material parameters on y-axis?
- *LOCAL COORDINATE SYSTEM ANSYS APDL ? how Ansys transform coordinates system?
- Material library
- PLA Material
- ANSYS 19.0 with Additive Manufacturing Extension
- How to add SN curve for new material in Fatigue analysis?
- properties of balsa wood
- Looking for Spring steel (55Si7) library material
- Ansys material damage
2706
2142
1355
1144
462
