Material’s elasticity
    • Luigi0
      Hi,nIn engineering data, when I select anisotropic elasticity, why I don't need to specify the poisson ratios?n
    • Luigi0
      I clarify the question: why when isotropic or orthotropic elasticity are selected, poisson ratios must be specified, whereas in the case of anisotropic elasticity poisson ratios are not required?n
    • BenjaminStarling
      With anisotropic elasticity, the poissons ration is defined through the ratio of normal strain between two variables (x - y, y - z, z - x).nPlease see this post https://forum.ansys.com/discussion/comment/59558#Comment_59558n
