TAGGED: act, ansys-mechanical, designxplorer, matlab-toolbox, optimization
December 7, 2020 at 6:33 pm
fetseck
SubscriberDear Ansys Forum, I am currently trying to start a test program using MatlabOptimizersForDX (https://catalog.ansys.com/product/5cc06907393ff65fd87cf921/matlab-optimizers). Using MOGA from Ansys when running DesignXplorer I have no problems and I converge to a solution. But using MatlabOptimizersForDX It won't even start the optimization. I simply get this error. -
December 9, 2020 at 10:41 am
fetseck
SubscriberSo, I didn't fix the problem but I know what it is.nI use Ansys 20 but MatlabOptimizersForDX is only for 19.2. I luckily had 19.2, so I tried it with that and it works. This is not ideal for me. An update is needed for MatlabOptimizersForDX.n -
December 15, 2020 at 1:17 pm
Karthik R
AdministratorHello,nACTs don't generally have the same update cycle as Ansys products. At this point, we don't have this ACT compatible for our 2020 products. It will be updated at a later stage. In the meantime, if your work relies on the ACT, I'd strongly recommend that you use the R19.nThank you.nKarthikn -
December 17, 2020 at 3:59 pm
fetseck
SubscriberHello Karthik,nYes, I will work with 19. Thank you for the info!nBestnn
- Local Sensitivity and Sensitivities: what difference?
- How many designs are generated while performing optimization using Optislang with NLPQL?
- Optislang workbench add-in
- DesignXplorer vs optiSLang for Workbench CFD Optimization
- Parameter relationships for Optimization
- ANSYS Optislang
- Errors about integrate executable into ANSYS Workbench using ACT
- DOE all design points give the same results as the first calculation
- Parametric study: Batch mode
- Design of Experiment points: Design Exploration
3744
2573
1809
1236
594
