September 6, 2019 at 3:02 pm
Jirong
SubscriberHi All
I am using transient structural to do the simulation with Mooney-Rivlin material. I got error said "Matrix coefficient ratio exceeds 1.0e8, check results carefully." and then highly distorted element was reported. What should I do to reduce the matrix coefficient ratio and how can I extract it?
In Analysis Settings, I turn on the large deflection, and use Damping for nonlinear control, and set stiffness coefficient to 1e-4 under damping controls.
I have used the same geometry with isotropic elasticity material before, it worked without matrix coefficient warning. Or is this because of my material ?
Thanks,
Jirong
September 6, 2019 at 4:54 pm
Sandeep Medikonda
Ansys EmployeeThis warning message means stiffness matrix of the model is ill-conditioned. Some elements have severe differences in stiffness from other elements.
The ill-conditioned matrix can occur due multiple reasons such rigid body motion, highly distorted elements, high frictional contacts, units that may results in numbers too big/small, or even unstable material models.
Generally speaking about this message, it is just a warning and can typically be ignored.
2080
1299
1106
459
