May 25, 2021 at 2:11 pm
thornyak
SubscriberHello!
If I have a multi-step analysis, how can I generate a maximum/minimum over time result? I would like to see e.g. the maximum stresses at each node from all of the steps.
May 26, 2021 at 7:22 am
Charudatta Bandgar
SubscriberHello Tamas
You can select the chart option for the maximum value in results to plot maximum stress over all the steps as a graph.
Regards.
May 26, 2021 at 7:39 am
thornyak
SubscriberHello Charudatta Bandgar
I mean, plotting maximum over time (over steps) result as a contour plot, not as a graph. If I have two or more loadsteps, I would like to see the critical areas (e.g. stresses) from all of the steps in one conotur plot result for the full geometry.
May 26, 2021 at 7:49 am
May 26, 2021 at 8:12 am
thornyak
SubscriberCharudatta Bandgar
If I select "All steps" under "Simulation Step" and the slider under "Substep" was set to "Last", then I will only see the contour plot result for the last simulation step (if "All steps" selected, then Substep equals Simulation Steps), right?
Instead of this I need such a result that displays e.g. the maximum stresses from ALL steps in ONE contour plot. In this case the maximum values for each node (max(Step1;Step2;Step3;...)) are plotted on the screen, like an envelope result. This called in ANSYS Workbench as "Maximum/minimum over time".
May 26, 2021 at 10:35 am
Charudatta Bandgar
SubscriberTamas I think that is not possible in AIM.
May 26, 2021 at 10:39 am
thornyak
Okay, thank you
- Copy user settings to new release
- Electric Heating – Ansys AIM
- Unexpected graphics error
- loss of user settings
- Dwg export error
- Can’t see license on online account
- Natural frequencies limited to first 6 modes
- Discovery AIM Mesh Error
- problem to access on the spaceclaim help
- Unsymmetric result
3720
2570
1777
1236
594
