January 13, 2023 at 9:57 pm
Chris Chase
SubscriberI wanted to automate plotting a series of Farfields and saving it by exportfigure(). However, they look small. Changing resolution by script does not help. Ideally I would maximize it manually and save it. How can I do this by script?
January 16, 2023 at 6:11 pm
Guilin Sun
Ansys EmployeeYou may try to use higher resolution. please refer this:
https://optics.ansys.com/hc/en-us/articles/360034410574-exportfigure-Script-command
after exporting, wen you open it, you can zoom in. Please try.
- Error on Lumerical device
2524
2066
1283
1096
459
