Maximum contacts stiffness is too big.
    • bugrrasen
      I am doing harmonic piezoelectric analysis in Ansys 2021 workbench, when I make precision mesh for piezoelectric bodies, I get this warning on the solution screen. Do you think it's an important warning ?
      "The maximum contact stiffness is too big. This may affect the accuracy of the results. You may need to scale the force unit in the model."
    • 1shan
      You may want to check the contact tool results and see if they look OK. If there is no sign of abnormality you can safely ignore the warning.
      Regards Ishan.
