Maximum member size error in topology optimization
    • Kushal Joshi
      Hello All,
      I am getting the following error when I set a maximum member size value. It seems to be a very high value considering my mesh size is 2mm. And moreover, I do not understand the term "Maximal element radius". What does it mean and how do I control it in Ansys Mechanical?
      Max member size error
      Best regards,
      Kushal
    • Ashish Kumar
      Forum Moderator
      Hi Kushal,
      Which is the Ansys version you are using?
      Ashish Kumar
      • Kushal Joshi
        Hi Ashish,
        Thank you for the reply. I am using Ansys 2022R1 version.
        Kushal
    • John Doyle
      Do you have a free tet mesh?   If so, you can interpret the max element radius as an average element size.
      • Kushal Joshi
        Thank you Mr. Doyle.
        Yes, I use a tet mesh and I can interpret the max radius value from the size. But my main concern is how can I control the radius? I want it to be as less as possible for the max member size constraint. For example in my case, even though the max element sizing I specify is 5mm in the local size controls, the radius is around 8-9mm. Is there anything else I need to do in mesh controls to reduce this?
        Kushal
    • John Doyle
      Can you insert a "Sizing" constraint under the Mesh Branch and specify behavior to be "hard"(under advanced options in details window)?
      It seems like your mesh is just too coarse.
Viewing 3 reply threads
