July 23, 2018 at 1:06 am
TomRochefort
SubscriberIt seems to be impossible to input more than 6 temperature dependant yield stress value in the bilinear isotropic hardening section inside ANSYS Workbench. I am using the Engineering Data module. Someone knows if we can input more points? The very small number of values seems to create spikes of plastic deformations once the temperature reaches these 6 defined points.
Thanks,
Tom
July 23, 2018 at 3:53 am
July 23, 2018 at 12:58 pm
jpasquerell
Ansys EmployeeTom,
The TB,BISO command documentation shows that the limit is 6 temperatures. The command input is via the a TBTEMP command followed by TBDATA with inputs for C1 and C2 then repeat for up to a total of 6 temperatures. I know of no way to get more than 6 temperatures for bilinear isotropic. Switching to multilinear isotropic hardening will allow more temperatures but requires input of temperature then values of plastic strain and stress.
Jim
2088
1319
1108
459
